Unsaved scripts
claudius06
Unsaved scripts
Post by claudius06 »
I want to create a new script (Libraries / Script Libraries), but once created, it doesn't appear anywhere—neither in the PFOA interface nor in the folder where it's supposed to be saved. Do you have any idea why?
Thank you,
Claude.
Re: Unsaved scripts
No.
Here it works like a charm. Where and how did you create the script. Make sure you add it manually to a folder where you have write access.
claudius06
Re: Unsaved scripts
Thank fo your reply.
I go to Libraries, then Script Libraries, then in the New Script window, I give a name to the file in Filename, I use category or create a new one the I click on OK. In the new window I add several lines then I click on OK to validate my work. But, when I return to the list of scripts, nothing has changed.
Sorry but I do not understand when you write "Make sure you add it manually to a folder where you have write access."
Re: Unsaved scripts
You are doing it as you just describe it.
So the only chance I see is, that you either don’t have write access to the given folder or you specified an invalid filename ?
claudius06
Re: Unsaved scripts
I had to replace the SSD in the computer a few days ago, so that's a perfectly plausible explanation. Can I modify that while PFOA is running? Do I need to change all the folders in the path starting from radio42, or just the target folder?
claudius06
Re: Unsaved scripts
I checked the permissions on the various folders, and they all have the necessary permissions. So, I restarted the computer, and after the reboot, I can create new scripts again.
Re: Unsaved scripts
Good to hear it is working again!
claudius06
Re: Unsaved scripts
Thank you again for your support.
