Crash after restart
claudius06
Crash after restart
Post by claudius06 »
After restarting the computer, PF launches and crashes right after displaying "Please wait, initializing audio devices...".
Could you help me?
Thank you,
Claude.
claudius06
Re: Crash after restart
I got these informations:
Nom de l’application défaillante ProppFrexx ONAIR.exe, version : 4.4.4.3, horodatage : 0x65f6096c
Nom du module défaillant : CTFXAS64.dll, version : 6.0.105.13, horodatage : 0x611dd3aa
Code d’exception : 0xc0000005
Décalage d’erreur : 0x0000000000011670
ID du processus défaillant : 0x20e8
Heure de début de l’application défaillante : 0x01db1f0df2707b67
Chemin d’accès de l’application défaillante : C:\Program Files\radio42\ProppFrexx ONAIR\ProppFrexx ONAIR.exe
Chemin d’accès du module défaillant: C:\WINDOWS\SYSTEM32\CTFXAS64.dll
ID de rapport : 1200f439-bc04-4da6-9a65-e3d06536b63b
Nom complet du package défaillant :
ID de l’application relative au package défaillant :
Application : ProppFrexx ONAIR.exe
Version du Framework : v4.0.30319
Description : le processus a été arrêté en raison d'une exception non gérée.
Informations sur l'exception : code d'exception c0000005, adresse d'exception 0000000075F31670
The mentioned module: CTFXAS64.dll
Is where it crashes.
But this module doesn’t belong to ProppFrexx. However ProppFrexx might use this system driver, eg. it might be part of your audio device or any other device driver?!
What have you changed? Have you maybe just copied all config files from another PC?
Close PF. Go to the ProppFrexx AppUserData folder and delete the file called ‚Default.mixer‘.
Then restart PF.
If that doesn’t help. Close PF and delete the entire ProppFrexx AppUserData folder.
claudius06
Thank you for your reply.
In the meantime, I tried a system restore to a recent date, but it didn't change anything. So, I am currently undoing the restore.
I added a video card earlier this month, but when I restarted the computer, PF restarted without any issues.
However, I noticed just before doing a system restore today that the installation of this video card (NVIDIA) led to the installation of an audio driver. I suspect this is where the problem lies. I tried to remove it, but I couldn't.
So, I'm waiting for the undoing of the system restore to finish, and then I'll proceed with deleting the default.mixer file (is there any risk of losing my audio configuration by doing this?).
claudius06
I was finally able to remove the driver installed by NVIDIA. PF restarted immediately after the computer reboot.
Thank you so much for your quick response.
Then just delete the „Default.mixer“ file as explained and all should be good again.
claudius06
After deleting 'Default.mixer', I need to restart PF or not? I ask this because I'm On Air.
As written. You close PF. Delete the file. And the start PF again.
The question is therefore obsolete.
claudius06
:oops: You're right and you have my apologies too. The question is therefore obsolete. :cry:
