UAC + Cartwall autoload on session login
jsonio
Post by jsonio »
With the UAC, when I log off and log in later, the loaded cartwalls disappear and i need to reload it each time.
I would like to know what is the best way to preserve a given cartwall library loaded into cartwall 2 between log off and the next log in for a given user.
Do i need to script and exec a command on the login action or is there some UAC authorization that need to be enabled to permit the cartwall state to be saved when the user log off?
Thank you very much in advance!
Jsonio
Re: UAC + Cartwall autoload on session login
I am not sure how you are testing things, but the selected Cartwall II is restored when the user logs-in again!
Here is an example for 2 users:
As you can see, for user 'Admin' the Cartwall II is restored with the last selected "/Jingles12-01".
And for user "Bernd" it is restored with the last selected "New Playlist".
So it works as expected.
