Stuck at restoring layout loading ProppFrexx when registered only after Windows 11 update.
phonic
Post by phonic »
After updating to Windows 11, ProppFrexx got stuck at the “Please wait, Restoring Layout…” message. On the next start, it asked for registration details. After entering them, it froze again at the same point.
Interestingly, when starting the application in DEMO mode, it launched fine and worked normally across multiple restarts.
As a temporary workaround, I launched in DEMO mode, registered in the settings, and it works until the next restart.
I’ve also upgraded ProppFrexx to the latest version.
Any idea what might be causing this?
Thanks,
phonic
Re: Stuck at restoring layout loading ProppFrexx when registered only after Windows 11 update.
Post by phonic »
It looks like some mixed up with the registration details for DRC and HK Studios.
I will send you an e-mail to clarify.
Your layout files got corrupted resp. Win11 uses a different screen management.
So close PF and delete all .layout files in the ProppFrexx AppDataUser folder. Then restart PF.
