sheduling new pfp library
Johnny_
Post by Johnny_ »
Hi Bernd, i try today new programms, for the non-stop buth the sheduller doenst add the pfp fyles i want add it from script sheduler new script it works but only when i say add en than will add playlist to today then be empty what i make?.
Re: sheduling new pfp library
I can hardly follow and understand what you are trying to do.
Can you maybe explain a bit more in detail (maybe with some screenshots and examples) what you like to do, what is not working.
How is your script looking today? and what should it so...?
Johnny_
Post by Johnny_ »
I want here some new add, but he don't do that. everything i try but i dont see the new script there.
Johnny_
Post by Johnny_ »
i make an file name :
Category : Duitstalig
Filename : Duitstalig - A-Rotatie - Uptempo
Ten fil i in all things, and add new script, but he dont see the new changes.
Do you have write access to your 'Default Script Folder'?
(that is the only option I can think of... and you recently changed your PC, if I am not wrong)
E.g. check here:
Johnny_
Post by Johnny_ »
Yes the settings ar one, i want to chang but i havent change right now its the same pc. and sd.
i think with the last update there what wrong?. i cant make anny new playlist right now.
I just tried it and it is working fine here, so no issues with the latest version.
As said, it can only fail, if it can not create a new script file.
Or what does happen, if you type in a new name for the new script (eg. ‚Test‘) and click on OK?
