Song Requests
allrequestradio
Song Requests
Post by allrequestradio »
I'm considering switching to ProppFrexx.
It offers more options than the software I'm currently using.
The only thing is, I use the Song Request function in that product a lot. It also plays the requested songs in the non-stop moments.
Is something similar possible with ProppFrexx?
I've seen an post of 6 years ago, but a lot could have changed since then.
Re: Song Requests
The status is still the same. You need to provide a web site/solution yourself.
I.e. a web site via which you can uniquely identify the tracks you like to use for your song request system.
You can then use a control-commands, e.g. PLS_CURRENT_APPEND_FILE, to add the newly requested song to the end of the current playlist.
This command either takes the fully qualified filename and path or the GUID of the track to add to the playlist.
