Playlist file (1 hour) on pc
gerritk
Post by gerritk »
Is there a playlist file for the playing hour some where on the pc? In a map or....
I have the Professional license. So no bulk pre render playlist for me.
I need this for 3th party company to put some items in. Example weather and local news.
Re: Playlist file (1 hour) on pc
Depends what you exactly mean and are doing?
E.g. if you just start a script via the scheduler and let the script run, there is no playlist file, as the playlist is rendered in real-time.
If you pre-create your playlists in advance and then play them (e.g. also via the scheduler) you can obtain
You can even pre-create script playlist in the Program Sscheduler. I.e. right-click in a program scheduler entry and select 'Create Playlist Template...'.
Once created you can even select 'Open Playlist Template...' to edit the playlist.
There is also an option to always pre-create all program entries as playlists - Automatic Playlist Template (Pre)Generation. See general settings, section Folders/Libraries and click on the 'Scheduler Automation...' button.
NOTE: That you need a commercial license! Any non-commercial license (which you have) is for private use only, no public streaming. And working with 3rd party companies doesn't sound like a private only use?!
gerritk
Post by gerritk »
Non commercial only experimental (hobby).
It's for AI weather forecast and local news voice. It needs something like *.pls with a placeholder entry for that kind of stuff.
As said above, a playlist file can be pre-generated. It is a .pfp playlist file. And yes, it can contain placeholders.
So that is „…something like that“.
Also note, that I have send you an email regarding the use of the commercial version.
You have a non-commercial version and it seems, that you are not using it for private use only.
gerritk
Post by gerritk »
Thx once more.
I reply to your mail. I only use Proppfrexx a few times in a month to hobby.
The local station I volunteer uses dutch software.
I try the .pfp file
