Drag previously played songs
Enkaavee
Post by Enkaavee »
Dear,
Suddenly, we can no longer drag already played songs (shown in red) into the playlist via Find. This used to be possible. I don't think any settings have been changed.
Sincerely,
Pieter
Re: Drag previously played songs
I can NOT reproduce your issue and there is also nothing changed in code. There is also or even a restriction implemented which might cause such behavior.
Are other Find Window entries (not already played) possible to Drag and Drop from the Find Window?
Maybe there is a general Drag&Drop issue on your system - as Drag&Drop is controlled by the Clipboard of the Windows OS - e.g. try a reboot of your PC.
Enkaavee
Post by Enkaavee »
I've restarted my PC. I can drag in other items that haven't been played yet.
Then you have explicitly changed the Global History Options yourself, i.e. this is not happening suddenly, but because you have specifically configured ProppFrexx to do so (something you thought you did not do...)!
See general settings, section Logging/History - click on the "More..." button next to the Global Song History and enable the "Ask for detected Duplicates" or change the 'Check Global History' option...
Enkaavee
Post by Enkaavee »
That's how it is currently. When I try to drag it in, it doesn't work, but when I enable Ask for detected duplicates and confirm the question, it inserts it.
That is what I just explained to you - e.g. read the tooltip I showed in the screenshot - that is what you explicitly configured, as this is not the default settings !
Enkaavee
Post by Enkaavee »
Solved.
Sorry for the duplicate question. My English isn't great.
Thanks in advance for the quick help.
