Hook points coloumn in playlist
Farbo
Post by Farbo »
Bernd, could you also add hook points (in and out point) or some coloumn that would indicate a music track has a hook point? Or maybe some length of hook point.
Peter
TheoOrl45
Re: Hook points coloumn in playlist
Post by TheoOrl45 »
In a general way, would it be possible to "customize" columns in the playlist, i.e choose the column we want to see and where...?
Theo, from France.
Sure, just right-click on a column header and select the 'Column Chooser...' tool.
Or select the 'Column Chooser...' from the ribbon tab.
You can also drag&drop he column headers to rearrange the position...
A new 'Hook' column was added in v3.0.11.13!
Farbo
Post by Farbo »
Thank you very much Bernd. Could you please consider adding also coloumn which will show the length of hook point?
Peter
