error when adding tracks from media library
Farbo
Post by Farbo »
Bernd, when trying to add tracks from librabry in playlist - right click - add tracks from the following error appears:
********** Error/Exception Information **********
Error Message: Exception of type 'System.OutOfMemoryException' was thrown.
Error Type: System.OutOfMemoryException
Error Source: ProppFrexx ONAIR.ProppFrexx.gb a(Boolean)
at ProppFrexx.gb.a(Boolean A_0)
at ProppFrexx.a8.a(aj A_0, Boolean A_1, Object A_2, Boolean A_3, String A_4, TreeListNode A_5, Boolean A_6, Boolean A_7)
at ProppFrexx.a8.br(Object A_0, ItemClickEventArgs A_1)
at DevExpress.XtraBars.BarItem.OnClick(BarItemLink link)
at DevExpress.XtraBars.BarBaseButtonItem.OnClick(BarItemLink link)
at DevExpress.XtraBars.BarItemLink.OnLinkClick()
at DevExpress.XtraBars.BarItemLink.OnLinkAction(BarLinkAction action, Object actionArgs)
at DevExpress.XtraBars.BarButtonItemLink.OnLinkAction(BarLinkAction action, Object actionArgs)
at DevExpress.XtraBars.BarItemLink.OnLinkActionCore(BarLinkAction action, Object actionArgs)
at DevExpress.XtraBars.ViewInfo.BarSelectionInfo.ClickLink(BarItemLink link)
at DevExpress.XtraBars.ViewInfo.BarSelectionInfo.UnPressLink(BarItemLink link)
at DevExpress.XtraBars.Controls.CustomLinksControl.OnMouseUp(MouseEventArgs e)
at DevExpress.XtraBars.Controls.CustomControl.WndProc(Message& msg)
********** End **********
Peter
Re: error when adding tracks from media library
That sounds like you are running out of memory (as the exception suggests).
What OS, what machine, how much RAM etc.?
Farbo
Post by Farbo »
I will find out, it is not on my machine. But it is strange it worked correctly before. This has just suddenly happened today.
Peter
Memory usage constantly changes and also depends on orher applications running in parallel.
Farbo
Post by Farbo »
So better to turn off all not needed applications and try out whether this error occurs.
Peter
That all depends on the machine, the available memory, the other apps etc.
However, of course it is better to have a system which doesn't run several apps in parallel!
