Showing Listenercount with different servers
Michael
Post by Michael »
Hi
Our streaminghost is using sc v2
I send the music to a sc transcoder with another port (7050), than the listeners connect to the sc server(7030)
In that case i can not see in the Network Streaming Monitor how many listerners are there.
Is there a way to make it possible to add a different server for the listenerscount?
Michael
Re: Showing Listenercount with different servers
You could add another streaming server without activating/starting it.
Or you use an external tool to monitor your listener stats - since that is not the native task of a broadcasting tool.
Michael
Post by Michael »
Thx, Bernd for the fast reply.
Adding another server does not work if the server is not active.
Michael
Ah yes, you are right, currently it will only update the stats, if connected.
I'll double-check this and try to update the stats even if not connected.
JonyKanal80
Post by JonyKanal80 »
radio42 wrote:I'll double-check this and try to update the stats even if not connected.
That will be GREAT i ask for it many months ago.... can wait for it.... :o
The new v3.0.11.28 now also shows the listener count for not connected servers.
See here for details: viewtopic.php?f=4&t=681
