Overlay player hangs
Michiel Bouwmeester
Post by Michiel Bouwmeester »
Dear Bernd,
The las 2 days \i have had 2x a crash of the overlayplayer. It just stops when playing.
I have rebooted the system and hoped for the best.
This morning however it stopped again but this time it did restart after a few seconds.
The following was in the log when I got home:
7-2-2013 8:36:19 [v3.0.11.31]:********** Error/Exception Information **********
Error Message: Object is currently in use elsewhere.
Error Source: System.Drawing.System.Drawing.Text.TextRenderingHint get_TextRenderingHint()
at System.Drawing.Graphics.get_TextRenderingHint()
at System.Windows.Forms.Internal.WindowsFont.WindowsFontQualityFromTextRenderingHint(Graphics g)
at System.Windows.Forms.TextRenderer.MeasureText(IDeviceContext dc, String text, Font font, Size proposedSize, TextFormatFlags flags)
at DevExpress.Utils.Paint.XPaintTextRender.CalcTextSize(Graphics g, String s, Font font, StringFormat strFormat, Int32 maxWidth)
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcSimpleTextSize(String Text, Boolean useHotkeyPrefix, LabelAutoSizeMode mode, Int32 predWidth)
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcTextSize(String Text, Boolean useHotkeyPrefix, LabelAutoSizeMode mode)
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcTextSize(Boolean useHotkeyPrefix)
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcTextPoints()
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcContentRect(Rectangle bounds)
at DevExpress.XtraEditors.LabelControl.LayoutChanged(Boolean isVisualUpdate)
at DevExpress.XtraEditors.LabelControl.LayoutChanged()
at DevExpress.XtraEditors.LabelControl.OnTextChanged(EventArgs e)
at System.Windows.Forms.Control.set_Text(String value)
at DevExpress.XtraEditors.LabelControl.set_Text(String value)
at ProppFrexx.ag.a(d3 A_0, Double A_1, gr A_2)
at ProppFrexx.d3.e(Int64 A_0)
at ProppFrexx.d3.f(Int64 A_0)
at ProppFrexx.d3.a7(Object A_0, EventArgs A_1)
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
********** End **********
The overlay constists of 3 files. 1: jingle, 2: news item, 3: jingle. Nothing has changed to the settings in the last weeks.
The first time I had this problem was last wednessday.
Machine: Intel 3Ghz, 4Gb ram, Win7/64. Ati video, M-audio sound card.
Re: Overlay player hangs
Should be fixed in v3.0.11.32!
Michiel Bouwmeester
Yet again thank you for the fast response!
I installed the update straight when it came out and have not yet seen any error's.
Michiel Bouwmeester
This error happened last night:
11-2-2013 22:00:44 [v3.0.11.32]:********** Error/Exception Information **********
Error Source: System.Drawing.System.Drawing.GraphicsUnit get_PageUnit()
at System.Drawing.Graphics.get_PageUnit()
at DevExpress.Utils.AppearanceObject.CalcDefaultTextSize(Graphics g)
at DevExpress.XtraEditors.ViewInfo.BaseControlViewInfo.CalcTextSizeCore(GraphicsCache cache, String text, Int32 maxWidth)
at DevExpress.XtraEditors.ViewInfo.BaseControlViewInfo.CalcTextSizeCore(Graphics g, String text, Int32 maxWidth)
at DevExpress.XtraEditors.ViewInfo.BaseControlViewInfo.CalcTextSize(Graphics g, Boolean useDisplayText)
at DevExpress.XtraEditors.ViewInfo.ButtonEditViewInfo.CalcTextSize(Graphics g, Boolean useDisplayText)
at DevExpress.XtraEditors.ViewInfo.ButtonEditViewInfo.CalcBestFitTextSize(Graphics g)
at DevExpress.XtraEditors.ViewInfo.BaseEditViewInfo.CalcBestFit(Graphics g)
at DevExpress.XtraEditors.ViewInfo.TextEditViewInfo.CalcMinHeightCore(Graphics g)
at DevExpress.XtraEditors.Container.ContainerHelper.CalcDefaultMinHeight(Graphics graphics, AppearanceObject appearance)
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonItemViewInfoCalculator.CalcEditHeight(Graphics graphics)
at DevExpress.XtraBars.Ribbon.ViewInfo.BaseRibbonViewInfo.CalcConstants()
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonViewInfo.CalcConstants()
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonViewInfo.CalcViewInfo(Rectangle bounds)
at DevExpress.XtraBars.Ribbon.RibbonControl.CheckViewInfo()
at DevExpress.XtraBars.Ribbon.RibbonControl.OnPaint(PaintEventArgs e)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
at System.Windows.Forms.Control.WmPaint(Message& m)
at DevExpress.XtraBars.Ribbon.RibbonControl.WndProc(Message& m)
The top part of the screen dissapeard and a big whit box with a red cross apperead.
Michiel Bouwmeester
After rebooting the following error appeared:
12-2-2013 8:41:37 [v3.0.11.32]:********** Error/Exception Information **********
at DevExpress.XtraEditors.LabelControl.OnHandleCreated(EventArgs e)
at System.Windows.Forms.Control.WmCreate(Message& m)
at DevExpress.XtraEditors.BaseControl.WndProc(Message& msg)
Michiel Bouwmeester
Ok Bernd, if you need me to do anything let me know.
That's a bit puzzling...as other users as well as my 3 test systems also don't have such issue...
However, I'll try to find the root cause of it!
Please try the new v3.0.11.33 - hopefully it'll fix your issue.
