notepad
Dolkis
notepad
Post by Dolkis »
I miss a notepad future so I can write my own script for the show in PF.
Just a easy input so I can write a litle.
(Moderator Track Information is to smal)
Dolkis
Re: notepad
Post by Dolkis »
Yes it was! Can you maybe add a fast button in the moderator info panel so I can swich between the original layout and my own layout?
Is it posible to have these saved in a own place, not with the songs. I dont have acces to out database and Im syncing it upp to out FTP server.
Te.x. Song is in this place:
C:my soungs\proppfrex\list A\
The Rich-Text documentalong-side will be in this place
C:my documents\music\texts\
Re: notepad
Please open the TAG Editor, go to the 'Tack Data' tab and click on the 'Ext. Document' button.
This allows you to create and edit a full Rich-Text documentalong-side with the track, which will also be shown in the moderator info panel.
Is that what you are looking for?
Re: notepad
Not sure what exactly you mean by this...
The Track Info (Moderator Info) window automatically displays what ever is available (a standard moderator text and/or an associated external document).
If both are available a toggle button is being displayed.
Is it posible to have these saved in a own place, not with the songs?
No, this is not possible, as it wouldn't guarantee unique filenames and links.
And yes, you might also add other documents to your playlist, e.g. a Word-Document, HTML-, PDF-, RTF etc. -File.
Any supported document format might be placed into a playlist and is available for preview.
