Cut function
DennisdeWit
Cut function
Post by DennisdeWit »
Something I would like to see in ProppFrex, is a cut function. Like Dalet, it would be nice to select a piece of the song, and then simply cut an remove the selected part. The Cue In function is nog working in the Segue Edition, so a cut function might be helpful.
Re: Cut function
The Cue In function is not working in the Segue Edition
It should actually work (and in a quick test it is working here)...so what is not working exactly in your case?!
Note, that you can right-click onto the WaveForm and select 'Cue-Points'...to define CueIn etc.
Or you might hold down the SHIFT key while clicking into the WaveForm to define CueIn (when at the beginning) or CueOut (when at the end).
A real 'Cut' function to cut a piece of audio in the middle of the track would be 'destructive'.
However, you might use the 'Loop-Sample' function (of the DJ Player resp. PFL Player) to define a piece of audio to be skipped!
DennisdeWit
Re: Cut function
Ahh, didn't know that! Thanks, Bernd :)
