Keyboard navigation in search results requires mouse click
szal77
Post by szal77 »
Good evening,
I’m preparing a playlist using the ‘Find track’ window. On entering the search string and pressing the Return key, it used to be possible to navigate in the search results using the Arrow-Up and -Down keys. This is not possible in v3.0.11.39—the first search result is highlighted, but pressing the above mentioned arrow keys yields no reaction. Trying to navigate the focus into the search results list with the Tab key fails—when reaching the list, the focus jumps to some other position. The only remedy is to click into the search results list with the mouse.
Please have a look into this. Thank you.
Kind regards
Sven
Re: Keyboard navigation in search results requires mouse cli
Indeed, that needs to be fixed!
Should now be fixed in v3.0.11.40!
szal77
Post by szal77 »
Fixed. Thank you very much! :)
