now playing on own server
- Soulmaster
- Contact:
hello , is there a way to send the nowplaying tags automatic to my shoutcast server. The music server and the shoutcast server are one and the same server.
and is there a script for sending the nowplaying to twitter ?
Re: now playing on own server
Something like this?
viewtopic.php?f=9&t=730
You might also for example assign the following command to the global 'Playlist.OnTrackPlay' event.
(see general settings, section 'Events/Commands')
Other control-commands might be used instead (depending on your web-site), e.g.:
- EXEC_SEND_HTTP_POST
- EXEC_SEND_TCP
- EXEC_SEND_SQL
- EXEC_UPLOAD_FILE
(see the User Manual Appendix for details)
On your web-site you might...
When using EXEC_SEND_HTTP_GET:
In your PHP script you can now access the params like this:
$artist = $_GET["artist"];
$song = $_GET["song"];
More info here: http://www.w3schools.com/php/php_get.asp
When using EXEC_SEND_HTTP_POST:
Use the following in your PHP script:
$artist = $_POST["artist"];
$song = $_POST["song"];
More info here: http://www.w3schools.com/php/php_post.asp
A certain Twitter update function is not available, but via the above you might easily implement something from within your web-site I guess.
EXEC_SEND_HTTP_GET http://domain.com/update.php?artist=${artist}&song=${title}- EXEC_SEND_HTTP_POST
- EXEC_SEND_TCP
- EXEC_SEND_SQL
- EXEC_UPLOAD_FILE
- Soulmaster
- Contact:
tnx
going to try this.
- Soulmaster
- Contact:
\o/ works GREAT...
XTended
The NowPlaying is working great on my site.
I read several topics here about pushing the nowplaying to Twitter, but I haven't found the right solution yet.
Does somebody who uses ProppFrexx push the nowplaying to Twitter at this moment and will you share it with me?
Ti push to twitter you cans use a simple ifttt.com recipe ... easy to do with a simple send mail macro
check mine https://twitter.com/nowonplayloud
Hi all,
the links are down and really i would try to send to Twitter artist/song title when change ... any info / help ???
thanks !
thanks !
