Watcher
workino
Watcher
Post by workino »
I need help how pass -usbreg to watcher.
Every time pfoa will start from watcher it ask for what registration method I want to use.
How I can solve it?
Thank
Workino
Re: Watcher
You can pass the same command-line arguments to the 'Watcher' as you would pass to ProppFrexx ONAIR.
Any command-line arguments passed to the 'Watcher' will be used when restarting ProppFrexx ONAIR.
If you are not passing any command-line arguments to the 'Watcher', the 'Watcher' will use the same command-line arguments ProppFrexx ONAIR was started with (if already running).
workino
Re: Watcher
Post by workino »
Thank you for all your job.
Best Regards
Workino
