Control command for local cardwall in VT module
andrerotgans
Post by andrerotgans »
I'm integrating a x-keys into my workflow and I'm programming it for a voicetracking workspace. Works fine, however to add functionality I'm looking for the control commands to fire off the items in de local cardwall. Just like the CW1_PLAY_CARD_1 command. Can't find a LocalCardwall or VT_Cardwall version. Does this exist ?
Kind regards,
André
Re: Control command for local cardwall in VT module
Instead of there being extra VoiceTracking-Cardwall commands, you might simply use the "CW2_xxx" control-commands!
If the VoiceTracking cardwall is opened the CW2_xxx control-commands directly relate to the VoiceTracking cardwall - else they relate to the standard Cardwall II.
andrerotgans
Ah, thanks, didn't try that, but it works ! Thanks !
