Scheduled start time when re-opening template playlist
andrerotgans
Post by andrerotgans »
Found a difference in the voicetracking of a pre-scheduled hour (the feature you created earlier this year)
When creating a new playlist (via New button, option Playlist Template Wizard) and start VT'ing right away, the scheduled-column in the playlist will start at the start time of the new playlist and populate from that point on. Right behavior, that way you can see where you are in the planned hour.
When you re-open that planned playlist from the Program Scheduler (to ie continue VT'ing), via right-click & open template playlist, the schedule-column of the first item will start at the time this playlist was opened again (ie the local time on you pc at that particular moment).
In my opinion this should be the same : the first one. Or is this planned like this ?
Kind regards,
Andre
Re: Scheduled start time when re-opening template playlist
No, you are right, looks like I have overseen this...and will correct it to be the target time being displayed as scheduled.
Should be fixed in v3.0.11.47.
