Traktor S4 jog
Traktor S4 jog
Can i use traktor S4 jog form command jogwhell of player?
and if it possible how i can do it?
Thank
Thank
Re: Traktor S4 jog
No currently there are no commands available to control the JogWheel.
I will try to look into it to add them to the next release.
Re: Traktor S4 jog
Ok perfect.
i need to ask you other.
i want try to comand kontrol S4 led but i can't understand how do it.
i will explain much better.:
i want to reset play led if in the djplayer there is not song load to off.
Or how can i specify to the player to start only when code is 127?
Thank
Thank
Re: Traktor S4 jog
May be these topics will help?
viewtopic.php?f=9&t=22
viewtopic.php?f=9&t=599
However, the exact MIDI message to toggle the LED must be taken from your Traktor S4 docs.
Re: Traktor S4 jog
hi,
years had passed. are there any changes regarding using midi jogwheel? is there an option to use jogwheel as jogwheel
Re: Traktor S4 jog
No. ProppFrexx has no plans to integrate Traktor controllers.
In addition ProppFrexx is not designed to be a DJ application for live mixing or perfect beat matching.
