Easy way to save all settings.
Dolkis
Post by Dolkis »
I want a easy way to save all the settings in PF (and ofc so I can chose what I want to save)
I know that I can go in to appdata and find it there.
For example.
In General Settings I want to save General/audio
Meta Data/waceform
Platlist setting
plater settings
mixing/fading and so on...
Can you inplant that?
Re: Easy way to save all settings.
Have you tried using the Backup and Restore feature?
You can find it in the 'Tools' ribbon.
