Error Report 1
RedPanda
Error Report 1
Post by RedPanda »
I was copying some audio files into a folder being watched by ONAIR and then suddenly I got this popup message from ONAIR:
03/07/2013 4:17:16 PM [v3.0.11.47]:********** Error/Exception Information **********
Error Message: Index 15 is out of range.
Parameter name: index
Error Type: System.ArgumentOutOfRangeException
Error Source: AsyncCtpLibrary.Void <SetException>b__0(System.Object)
Server stack trace:
at System.Windows.Forms.Control.ControlCollection.get_Item(Int32 index)
at ProppFrexx.dm.b(Boolean A_0)
at ProppFrexx.dm.e.a()
Exception rethrown at [0]:
at System.Runtime.CompilerServices.AsyncVoidMethodBuilder.<SetException>b__0(Object state)
********** End **********
This was of course while ONAIR was open, but not actually running or doing anything. Just sitting open.
Thanks
RedPanda
Re: Error Report 1
Post by RedPanda »
Ok, good to know.. just to let you know after I pressed continue, the pop up occurred 2 more times. Once for each file that was added.
Re: Error Report 1
yes, I can spot the error, which is actually a race condition, which might happen quite rarely, but yes, it seems, that it can happen.
Nothing serious though...you can safely press continue without any issues.
I'll fix that in the next release!
Re: Error Report 1
Should be fixed in v3.0.11.49!
RedPanda
Re: Error Report 1
Post by RedPanda »
Wow! You are awesome! Thanks!
