Top of the hour
Soulmaster
Top of the hour
Post by Soulmaster »
Hello, i'm trying to make a top of the hour.
What i did is making a playlist with in that playlist first a jingle, than news, jingle.. works great but....
1. the news is never the same lenght so sometimes halfway the new the jingle starts. how to fix this? ,
2. when the top of the hour ends with the jingle there is silence for 2 á 3 seconds before the music starts.. how to fix this?
futher... i bow for the makers of proppfrexx what een masterpiece of software..
Re: Top of the hour
I thought it already all worked according to this thread?
viewtopic.php?f=9&t=856
Also take a look here:
viewtopic.php?f=9&t=31
to 1:
I do not fully understand your issue.
A single (playlist) script just plays the items one after the other one.
You might need to use either a Fix Time Element or an Overlay Scheduler entry or another Program Scheduler entry.
See the above links for details.
to 2:
How do you play/schedule the TOTH?
See the first link above - I recall, that you already asked exactly the same...
Soulmaster
Re: Top of the hour
shall try your options. tnx.
I did it like this.
Soulmaster
Re: Top of the hour
close this topic :) found the old one.
