Unable to sort by "schedule time"
amaurydixx
When I generate a playlist (I generate a playlist for each hour in my webradio), I sort the playlist by artist to assure that there is no duplicate entries (I have sometimes problems with the history).
But after, I'm unable to sort the playlist by the schedule time...
When PFOA plays the playlist, It plays it in the wrong order...
Thank you.
Amaury
Thank you.
Amaury
amaurydixx
Re: Unable to sort by "schedule time"
Thank you Bernd...
It works!
However, is it normal that PFOA plays playlist in the display order and not in the schedule order?
It works!
I guess you want to 'clear' the sorting (as this restores your original ordering)?
If so do either one of the following:
- right-click on the playlist and select 'Miscellaneous - Sort - Clear Sorting'
or
- use the ribbon button 'Clear Sorting' in the 'Miscellaneous' tab
or
- click the very upper left tree list column header button
or
or
There is no 'schedule order'. The 'Schedule Time' column is automatically calculated.
PF always plays the playlist in its current 'appearance' from top to bottom.
