Remove all overlays created by an advert pattern wizard
andrerotgans
Post by andrerotgans »
Is there a way to remove all overlays created by an advert pattern wizard, without having to delete them manually one by one ? This to make it a little bit easier to experiment with things. Right now I (if I don't forget....) create a snapshot of my VM, but as you can image I sometimes forget. It's a pain in the bum to delete 100+ overlays by hand ;)
It's no problem if that action deletes all overlays (so news and manually created ones also)
Regards,
André
Re: Remove all overlays created by an advert pattern wizard
All overlay entries are stored within the resp. calendar as configured.
As such you can copy that .calendar file to make a backup.
After your tests you can simply restore the .calendar backup file.
However the Advert Pattern Wizard might also create related Slots.
This is done within the 'Slot' sub-folder of your Advert-Storage-Path.
As such you might backup this folder as well.
radio42 wrote: However the Advert Pattern Wizard might also create related Slots.
I can't find a slot sub-folder.
Only a slots.cfg file.
Uups, sorry, it is the "slots.cfg" file - not a sub-folder!
So basically just backup and restore both of these files:
- slots.cfg
- Overlay.calendar
