Fatal error after opening the scheduler window
amaurydixx
Sometimes, I've got a problem when I open the scheduler window.
The message:
« 18/01/2014 10:41:56 [v3.0.12.10]:********** Error/Exception Information **********
Error Message: Parameter is not valid.
Error Source: System.Drawing.IntPtr GetHdc()
at System.Drawing.Graphics.GetHdc()
at System.Windows.Forms.Control.DrawToBitmap(Bitmap bitmap, Rectangle targetBounds)
at DevExpress.XtraScheduler.SchedulerControl.CreateControlBitmap(Bitmap bmp)
at DevExpress.XtraScheduler.Animation.Internal.LastPaintInfo.CreateOrReuseBitmap(SchedulerControl control)
at DevExpress.XtraScheduler.Animation.Internal.LastPaintInfo.ObtainCurrentAnimationInfo(SchedulerControl control)
at DevExpress.XtraScheduler.Animation.Internal.SchedulerAnimationManager.Paint(PaintEventArgs e)
at DevExpress.XtraScheduler.SchedulerControl.OnPaint(PaintEventArgs e)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
at System.Windows.Forms.Control.WmPaint(Message& m)
at DevExpress.XtraScheduler.SchedulerControl.WndProc(Message& m)
********** End ********* »
Thank you.
Amaury
The message:
Thank you.
Amaury
Re: Fatal error after opening the scheduler window
That also indicates a graphics issue (which proves, that my other comment to your other post is correct).
Please reboot your machine...and report, if that error comes up again.
If not, that was clearly a OS/System issue and not a PF one.
amaurydixx
Bernd,
After updating my OS, after rebooting my compturer and after updating PFOA...always the same errors.
I run PFOA with Windows 8...any other bugs reported?
- Sometime the scheduler window opens with a big white screen (and a big red cross in the middle)
- Sometime my screen blinks and few second later...PFOA stop working (with an error message).
- sometime the software do not respond and restart...
I've got 2 different graphic cards and the problem is the same with both of them.
Thank you.
Thank you.
I am afraid, that there is not much I can do. There are also no know ProppFrexx issues with Win8 or Win8.1 - except the common and known Windows8 issues.
You might try the latest v3.0.12.12 version.
And also try to upgrade to Win8 SP1 or better Win8.1.
But the error clearly indicates, that no additional window handle could be created due to a Graphics Handle error.
And this is being managed by .Net resp. the graphics driver.
Are you really sure, that your graphics card/driver is fully Win8 certified and compatible?!
amaurydixx
Bernd,
I updated my windows version (8.1 now), my graphic cards drivers...and since, no errors...
But this morming another crash when i opened the voice track windows...
I don't know if there is a link...
The message:
17/02/2014 07:26:42 [v3.0.12.11]:********** Error/Exception Information **********
Error Source: System.Drawing.System.Drawing.Imaging.ImageFormat get_RawFormat()
at System.Drawing.Image.get_RawFormat()
at DevExpress.Utils.Controls.ImageHelper.MakeTransparent(Image image)
at DevExpress.XtraEditors.Repository.RepositoryItemHyperLinkEdit.set_Image(Image value)
at ProppFrexx.ab.b()
at ProppFrexx.ab..ctor(Exception A_0, Boolean A_1)
at ProppFrexx.c8.b(Exception A_0)
at ProppFrexx.c8.a(Object A_0, ThreadExceptionEventArgs A_1)
at System.Windows.Forms.Control.ControlNativeWindow.OnThreadException(Exception e)
at System.Windows.Forms.Application.Run(Form mainForm)
at ProppFrexx.dw.a(String[] A_0)
********** End **********
Thank you.
Amaury
The message:
Thank you.
Amaury
amaurydixx
Thank you...
I'm gonna try to update PFOA asap.
The again looks like the same graphics error.
But it is still not the latest PF version
- which is already v3.0.12.13!
