ProppFrexx Tagger Free Standalone
RedPanda
Post by RedPanda »
Hi!
I enjoy using the free tagger program you provide where we can edit our files and make cue points etc. outside of the DJ program.
A request that would be really cool is if you could add to allow to load 1 DSP in the volume control area somewhere. So durring playback we have the option of the raw sound, or the processed sound through a DSP.
Reason for this is I like to load the songs and the DSP and play the songs through the DSP in order to set cue points on the fade outs of songs. Because the DSP I use is AGC and it brings the volume up on the end of songs and it's easier to catch the AGC'ed fade out of the song with active AGC/DSP rather than setting it on the raw unprocessed audio because when that is played through the AGC later, the volume change point and cue are not set to the processed sound and often end too early with full volume.
Anyway, it's just a little something that would be nice to have as an option. This would allow perfect cue point settings on processed audio.
Hope it's not a difficult thing to do.
Re: ProppFrexx Tagger Free Standalone
Fair request. I'll put that on my list.
workino
Post by workino »
I just add some other request to this post.
i noticed the tagger don't save properly all data. (so please improve save data function)
If it posible improve also bpm counter because a lot of time it was wrong.
and, i know only my crazy mind can ask something like this, but can you integrate also discogs for retrieve the tag?
workino
Post by workino »
when i click on save data some time it not want write the modification such acpd or replay gain or bpm.
I just completed my post with some other request :)
How are you testing these things (when the data is not saved)?
As this was tested a lot of time and so far it was always another issue or the testing which was wrong.
Note, that the track should not be playing - otherwise the saving might get delayed. The track should also not be loaded/used elsewhere!
- the BPM detection depends on the music/track being used and can not be improved.
With some sort of music a BPM can not be detected perfectly and as such must be manually adjusted.
That is normal.
- Discogs integration is also not planned at the moment.
I might put it on the WishList, but I am afraid it gets a pretty low priority
RedPanda
Post by RedPanda »
I got all excited, I thought Bernd was gonna say he released an update version. awwww...
?Please explain in detail - what exactly is not saved?!
What is 'all data' ?
What exactly is not saved?
The VST support for the tagger will go into the next verison - sorry ;:-)
RedPanda
Post by RedPanda »
DSP as well? I hope! :lol:
A VST is a DSP!
What DSp are you using?
