Problem activating MIDI-control
Joche
Post by Joche »
I try to activate and use a Zoom R16 with ProppFrexx, however as soon as i activate anything with MIDI in options ProppFrexx hangs. I can't even assign commands to the midi-interface. Have you got any idea why this happends?
(Using ProppFrexx 3.0.12.12)
Best regards,
Joche
Re: Problem activating MIDI-control
Do you mean you enable the MIDI control within the general settings?
Any specific errors you get?
Anything reported in the Windows Event Log?
However, it more sounds like a MIDI issue of the device...
Many MIDI controllers can be configured to run in various different modes, like a 'Pro Tools', 'Cubase', a generic 'Mackie' mode etc.
So may be you have selected the 'incorrect' mode?
Please see the manual of your MIDI controller and try different modes.
You should try to select a generic MIDI mode.
