ProppFrexx Switching Users and TeamViewer
louis
Post by louis »
A small issue-- I can't seem to change users in ProppFrexx while logged in with TeamViewer... I'm not sure if their is just a basic compatibility issue, but ProppFrexx hangs on the "Please Wait, changing user interface layout..." message. The only way I can seem to recover the program is restarting it.
As I'm remote, I can't tell if the issue happens in the studio as well as remotely.
Re: ProppFrexx Switching Users and TeamViewer
It definitly does not happen 'onsite' - as many users are using it...
I was even recently in a remote TeamViewer session with a customer who also used UAC and we changed the Users (Logoff/Logon) quite frequently without any issues, so I suspect, that it is somehow machine related?!
XTended
Post by XTended »
We had the same problem with Teamviewer and in the studio; best solution was to remove the old layout files and build up again.
But the best solution was to work with the PFOA Media Library Server, switching from admin to standard user account with Teamviewer and in the studio goes fast and saves so much internal memory and CPU use. Maybe a solution for you?
