[VST] Scanning My Folder Crashes ProppFrexx OnAir
sun7radio
Post by sun7radio »
OnAir is crashing when I try to scan my VST folder.
I have quite some but I'll try to isolate the plugin(s) that might cause the crash.
Meanwhile, are there known VST plugins that crash OnAir ?
Cheers,
Guy.
Re: [VST] Scanning My Folder Crashes ProppFrexx OnAir
Yes, all WAVEs plugin (and sub-type VST plugins) are currently unsupported.
Also are only 32-bit plugins supported.
As such the crash might happen within the VST dlls (while loading them) - as such there is unfortunately not much to do.
It is advised to use ONLY those VSTs (placed in an extra folder) which are really being used.
sun7radio
Post by sun7radio »
Good idea, I'll do that indeed. Thanks.
Cheers,
Guy.
