audio routing and rodeaster pro2.
Johnny_
Post by Johnny_ »
Hi, anybody to help, i have an rode rodeaster pro 2, but the sound wil not correct on the mixer chanels. i doing get wrong.
I hop bern wil help me or anybody els, soon ass possible. the sound is now totaly mono.
Re: audio routing and rodeaster pro2.
If you tell me what you like to achieve and what is currently wrong I might help.
But with that little info I am afraid au can not help much.
Please explain in more details what is not working and what you like to achieve.
Normally you just setup the Mic as an Mixer Input Channel device.
Johnny_
Post by Johnny_ »
i have now an mono sound, but i have also set stereotool. the stream is on daytime on auto dj. im writing on 23.52 dutch time. the sound is not good on mono. only flac from cd.
Johnny_
Post by Johnny_ »
when i change to that, then is stereo but oceansounds. and i ant not talk or play music on my mixer. the live. the sound always same. strangs.
I can hardly follow and understand what you are saying.
You have posted an input and an output mixer channel settings.
Is you problem, that the MIC signel is Mono?
If yes, note, that any Microphone is always mono.
But in your Input settings, you finally selected the Rodcaster output as the recording device instead of the Microphone?!
That doesn’t seem to make sense.
Also note, that you should not mix the device modes. Ie. use WASAPI on all devices.
Johnny_
Post by Johnny_ »
radio42 wrote: 01 Sep 2026 08:58 I can hardly follow and understand what you are saying.
When i do that, then wil it not work, anytime, could please a licence reset for me?. i have installed just a new vps for my station. you an send me a payment for me.
There is no license reset!
And I still do not understand your issue!
So I am guessing your mic input channel is mono?
For your Input Mixer Channel:
Use the Microfoon Rodecaster Pro II device!
Route the single to an output channel (eg. PLAY).
Set the processing either to Stereo or Normal Mono (right-click on the input channel name and select Processing…).
Set the StereoTools VST on the output mixer channel and not the input mixer channel.
For the Output Mixer Channel don‘t use the Rodecaster device, but any other audio device.
